Where can I find carb rebuild part number?
PMP
Hey guys,
Where can I find the part number for the carb rebuild kit for my engine?
The serial number on my Mercruiser 4.3 block is 022226
Any assistance would be great.
Thanks
PMP
Re: Where can I find carb rebuild part number?
If anyone can even point me in the right direction that would be fantastic.
Does my Serial number look correct?
Sorry, but that's not a Mercruiser serial number.
There should be a metal tag just above the stater with the number on it.
PMP
This is the tag I got that from.
I see the problem, the tag is bent over and I really can't see for sure, but it looks like there is an L there, can you verify?
attachment.php
PMP
hmm.. I Just checked.. It is easyer to see the tag in the photo then it is on the block. I can hardly read the 022226.
It looks like an L or an I
Fun Times
Is the boat somewhere around 1997 or 1998ish ?
PMP
yeah its a 98 stingray
Fun Times
Then it an "L".
Engine serial number 0L022226 is a 1998 MERCRUISER 1 PC W/PS 4.3L ALPHA.
You will need to know if it's a 2 or 4 barrel carb.
You can find the part numbers below. Then try running the part numbers you find below here at iboats marine store for a better deal and faster service.;):) Good luck.
http://www.mercruiserparts.com/selectDocs.asp?doc_nbr=809969+98
