Where do I go from here? Melted spark plug
D_J_Winn
I have a 1997 MerCruiser 5.7LX (OKO26695) Bravo 3. I have been experiencing slow starts, rough idle, backfires at 40k rpm and can only achieve 41k rpm WOT.... as opposed to 47k. Today i dove into the engine and to my surprise i found #2 cylinder spark plug melted away after the threads. All others are fine. Looking for help in regards where do i go from here? Can anyone point me in the right direction, have any other ideas or suggestions? Thank You in advance.
Planing on pressure testing, installing a new distri. cap, and installing a new fuel pump. (things i have been wanting to do)
Not sure if this has anything to do with it, but i did have manifold and risers installed last yr.
PS94
Re: Where do I go from here? Melted spark plug
burning too lean/hot(bad intake gasket), detonation, rusted away, steam erosion? Got access to a boro-scope?
Capt Ken
Possible intake leak causing a lean burn in that cylinder.
achris
More fish than mountain goat
Burnt plug, 40,000 revs... Not surprised!!! :eek:
Jokes aside. Very first thing, check compressions. Then check your timing, and that includes the timing advance. Also check your leads. A bad lead can cause a burnt plug too...
Chris.......
makonnen
Could it be possible your engine swallowed something and it beat the crap out of the plug? Ie: swallowed a wingnut or something like that?
gm280
Not saying that couldn't have happened, but a wingnut would mean both the intake and exhaust valves would have to open up really wide to allow such to get through...
Ayuh,.... The most common cause of Detonation in a boat is bad gas, dirty gas, 'n plugged filters...
'n yer problem sure looks, 'n sounds like Detonation,...
Don't keep pushin' it, when it does it, or it'll be a Hole in a piston next time....
Probably got a good start on a hole now...
Inspect the contents of the fuel filter, insteada just throwin' it away,...
I'd Test the fuel pump, insteada just puttin' on a new 1,...
Speakrdude
Ensign
Was the spark plug "loose" when you removed? I have had that happen before. The loose plug causes a lean condition on that cylinder and will melt that sucker every time.
I will usually "tulip" the Intake valve too.
D_J_Winn
Thanks guys for the help-
Unfortunately I wont have time until next Wednesday to work on her, but I'll be sure to update what i find.
Speakrdude- Not sure if it was loose (i can only hope) due to the threads being melted on the spark it was pretty hard to remove...might have to re-tap
