Where do you get long aluminum rivets?
mikezohsix
I read in a post a while ago that you could get long (.75 inch) rivets at the local auto parts store, since home centers don't have them that long.
I've been to a couple, and all i could find is .75 inch steel rivets, that are a #11 drill dia. They seem to be close to the 3/16 rivets I normally use, but don't want steel rivets in my aluminum boat holding the floor to the stringers.
Where should I be looking?
TitanTea
Re: Where do you get long aluminum rivets?
Search Ebay. Thats where I got a great deal on aluminum rivets. :D
18Starcraft
If you have a Fastenal around you. I've gotten the 3/16 aluminum rivets. They have them in various lengths. Even when I specal order takes 3 days and get a bag of 50 for around $15 with shipping.
lowkee
I got mine at Northern Tool. They have a decent selection, and the price isn't bad considering you avoid shipping. I also got a nice two-handed rivet gun from Harbor Freight for $15 which works very well (beats my old craftsman riveter hands down)
mikezohsix
Thanks for the info...
When the give you the grip range, why do they specify a min dimension?
My experience is that they'll pull down to almost nothing.
With 1/2 ply, glass on both sides, and trying to rivet to aluminum stringers, I'm right at the 5/8 length.
Should I err on the long side and get the .625 to .750 or the .500 to .625?
I got lucky I guess and ACE hardware had aluminum rivets 3/16 x 3/4 which are good.
Go for the .625 - .750 and you should be fine.
jspano
i'm not sure but down here 1/2 ply is more like 19/32 or something like that, don't forget to figure that
mikezohsix
thanks guys,
I'll take another look in some other ACE hardware stores.
McM Carr had 100 for $7, which is pretty cheap, but requires shipping.
I'm going to check out Grainger, which I hadn't thought of until McM came up because there is one local.
mk
jeeperman
3/4" body length rivet is only good for 3/8" to 1/2" material thickness, according to Mc Carr.
At $10.16 per 100 you might want to use these:
http://www.mcmaster.com/#97447a090/=59bsmv
Aluminum rivet and mandrel as well as extra big head diameter of .65" which your fiberglass will like versus standard head diameters.
I love McCarr as anything I order today will be here by noon tomorrow via regular ups Atlanta to Pensacola.
