Where does the 4.3 GS PCV hook up to vacuum? I am doing a 2 to 4 barrel conversion
smassey22180
My newly purchased used intake and carb has arrived and I think everything is going to work out. The only thing not lining up is the PCV hose fitting. On my 2000 2 barrel, it hooks to a fitting on the rear of the carb base plate. The 4 barrel base plate (from a 1997ish) does not have a fitting. The base plate probably can't be tapped in back like my 2 barrel. I could tap a fitting just under the adapter in the manifold but I figured I would ask what the factory did before I started drilling holes.
Also, the 80487 carb needs a rebuild. Holley had a kit 703-66 but it has discontinued it. This 4160 carb does not have a powervalve which seems odd. Any insight on this is appreciated.
thanks
the valve cover breather tubes do not have a PCV valve, and they should connect to the top of the spark arrestor
yes, this spec for volvo doesnt have a power valve
http://boatinfo.no/lib/volvo/manuals/md_fuel/pages/page_l87.swf
My experiend where someone installed the power valve eliminator plug is then the fuel economy sucks because you have to go up 6 jet sizes on the primary side to get it to run at partial throttle. however per the spec, thats how your carb was set up from the factory.
I also find the the marine carb is listed as 500cfm, however the auto version (80487s) is listed as 600 cfm
smassey22180
Thanks for the info. So GS 4.3 does not have a PCV valve like my 2000 GL 4.3? I currently have a breather on the port VC and PCV valve on starboard. And I was wrong above. My vacuum line hooks to the base plate and not the adapter.
dan t.
So drill and tap a hole in the adaptor plate and thread in a fitting so that it pulls from both sides equally. I have converted 3 boats that I have owned to pcv systems with no problems at all . In fact once you have had a valve cover rust out from the inside you will soon realise the value of pcv. It is far superior to the passive breather system that most marine engines use. A pcv pulls the moisture laden crankcase fumes out of the engine and pulls fresh air in, the result is a motor that is far cleaner and drier inside than one with a stock passive breather system.
smassey22180
My adapter plate is not thick enough to tap. It is double walled which also makes it difficult. The base plate of the carb is also too thin. I can tap the side of the manifold but that will not put it evenly in the center. The 4 barrel intake has a crossover unlike the 2 barrel so do you think the a vacuum on the side is good enough. My old 2 barrel intakes use one barrel for each side of the engine. The new 4 barrel does not isolate one side of the carb for that side of the engine.
dan t.
If the only place to tap in is the side of the plenum I would tap into both sides and "T" the hoses together then hook to the pcv hose. I would not tap into 1 side only, even with a crossover this would lean that side out. In fact I would make sure that the hoses from the sides to the "T" are of equal length so that they draw evenly.
smassey22180
I was finally able to get a port in the adapter. The double wall was a around an inch thick and did not allow me to simply tap something in. I took a male to male 3/8" hose fitting and ground the barbs off of one side to make is smooth. I was then able to drill out the adapter plate to press in the new fitting.
dan t.
Glad you figured it out, you wont regret running a pcv, much happier motor
