Where does this hose go from the fuel Reservoir
alanjb
This is a recent purchase/project for me and I have notice that I have a rubber hose coming off my VP 5.0Gi pwtr fuel reservoir (high pressure pump) not going to anything. According to the parts diagram it should have a Impulse Limiter on the end of it. Also I do not know where it connects to. I have also found the fuel pressure is 36 psi instead of 30. Engine seems to be running good after giving it a little attention over the last couple of months.
Fun Times
I was able to locate some info below that should help with your question of where the hose should run to.
https://www.justanswer.com/boat/5r9b...pump-boat.html
I took off line number 38 on the parts list and it had fuel in it, hopefully this is the hose. This hose goes from the vst to a fitting on the manifold just below the throttle body.
http://www.tarakona.hu/hajofelujitas/
0435009 - Pulse Limiter
Part Number
0435009 Johnson
0435009 Evinrude
435009 Johnson
435009 Evinrude
VRO applications: If your motor is older than a 1993, make sure it has the blue colored pulse limiter to protect the air motor and the check valves in the pump.
Evinrude Johnson OMC Pulse Lmtr-w/thrds 0435009 is equivalent to parts:
  • 3852225 Volvo Penta
  • Here's a Pulse Limiter "image" of listed part numbers too as it may help you find it quicker.
Manufacturer
CURRENT
alanjb
Got it. Thanks for the help. This hose was disconected when I purchased the boat. Hopefully this will improve performance
