Where is serial number on Mercruiser 5.0
hz293
I believe my engine has been replaced on my 1989 Chaperral with 5.0 engine. The only reason I think it's a 5.0 is because the cover over the carburetor r says so. I don't think they made that engine in 1989 but I could be wrong. From what I've seen they started in 1992 is that right. Anyway it's super clean and I don't think it's been used much. Where would I find the serial number on the engine? Did they make any other designation other than the MPI and EFI?
Fun Times
Hi there, If you can't find the serial number from the info below, then try this method, http://www.marinemechanic.com/merc/distributors/mercurymarine/sterndrive/gmblockcodes.PDF
Where to Find Mercruiser Stern Drive and Engine serial numbers.
Drive units
In-line Engines
V6/V8 Engines
