where is the regulator/rectifier??
glastron50gl
I have a 2003 5.0 GL-C Volvo Penta motor. The tach stopped working but checks out as OK. I removed the tach and ran it on a friends boat and it works fine. It gets 12vdc of power and the needle "zeros" when I turn the key. The signal is is saying 9vdc but the tach will not move. I though I should check the rectifier but not sure where it is. Thanks Steve
Re: where is the regulator/rectifier??
The tach should be getting pulses from the ignition coil. You are meausuring the DC voltage from the coil...not pulses.
Make sure your ground to the tach is ok.
