Which generation?
rocky100
I have a 2001 i/o mercruiser 3.0-how can i tell if it is a generation I or II?
is it determined by the year of production from mercury?
Re: Which generation?
Ayuh,.....
The Year is a Good indicator,....
And,....
They just Look different......
Your's is a Gen.II.......
rodbolt
dunno as mercury marine never used year of production as an indicator and its not uncommon to see older or newer desin engines in various hulls.
easiest way to tell a genII from the alpha is to look at the anchor pin for the trim cylinder. the alpha uses nuts and the alpha genII uses E clips.
1990 was the last year of the Alpha I (Gen 1 as you call it)
1991 to present is Alpha I Gen II drives.
rodbolt
like I say, the year of the hull manufacture date may not coincide with the year model of the drive package.
brunswick marine uses engine,transom shield and drive seriel numbers for any and all identification purposes.
