which prop?
mfo
I was looking at a 17 ft. charger the pacesetter series which used to be an entry glass boat rather narrow beam anyway it has a 1998 90 hp rude which prop should this use I have looked all over the prop that he has on and can't find a single number , it is a stainless one i think. It seems like it takes about a good 5 sec before it gets up on plane with 2 adults and 15 gallons of fuel with 3 batteries? This is with it WOT.
thnx,
mark
Re: which prop?
Your Question is Unanswerable without knowing What the WOT RPMs are now,....
And,... The Recommended WOT,RPMs of the Power plant,...... And the Pitch of the Prop on it to start with.....
Btw,.... The #s on that prop, are Probably under the Nut, next to the Shaft....
