Who releases a spring loaded kicker bracket while standing over it?
jc55
...This guy. Probably the dumbest thing I've ever done. It was in the full down position and I was standing over it, on the ground when I couldn't get it to release. Well, it released right into my nose. It dropped me and I bled all over the yard. Please be careful doing the obvious, lol. So dumb!
Grub54891
Re: Who releases a spring loaded kicker bracket while standing over it?
Are you the guy that stands on the branch and cuts it off the tree??:embarassed:
Lol
tomhath
Easy mistake to make. Hopefully no permanent damage.
JimS123
If you're in the boat how can you possibly release it without standing over it? It has an 11" travel. Use your hands and keep your head a foot up.
jc55
No, I was on the ground standing behind it...yes, very dumb!
GA_Boater
Only once!
greenbush future
I really dislike the kicker brackets that you describe, all of the one's I have used, are a pain in the butt to deploy and use in general. Your mistake is a new one, but as stated, only once. Glad your OK. I dumped the kicker, and went to a bow mounted trolling motor, the bracket is still there, but I don't use it anymore, too hard to deploy and then operate when fishing, I had to sit in that corner of the boat, and constantly adjust, leaning back and over the transom. Every boat is different, you will get better at using it.
JimS123
OMC used to make a kicker bracket with no springs, but a hydraulic cylinder to assist it going up and down. Simple to use, no effort required and it moved as slowly or as quickly as you wanted it to go.
They were so good that a few years ago when I had the chance to buy a NOS model on EBay I jumped at it just so I'd have a spare for the future if I ever needed one.
My current boat has 30 seasons on it with this bracket. I've never demounted the motor and I've driven on the highway all these years with the motor and bracket in place.
jigngrub
You could have gotten a million hits on youtube if you had gotten that on video!
jc55
LOL, probably so.
81_chapparel194
its called self correcting behavior... bet you don't do that again.....:facepalm:
