wht kind of adhesive do i use to put top on hull
slogen
i am ready to put the top back on my hull, but before i rivit and bolt it back together do i need to glue it it/siliconeit first?
jonesg
Re: wht kind of adhesive do i use to put top on hull
I used PL premium construction adhesive on mine, its cheap , tough and allows over 30 minutes for positioning.
Do not use silicone ....... it will not last. You can use a PL adhesive or 3m 4200 or 3m 5200. If you EVER anticipate cap removal again go with the 3m 4200 which will permit this. PL and 5200 are permanent
drewpster
I did not use anything. The OEM did not either. But then I only boat in fresh water. If you go in heavy seas then sealing the joint would be a good idea. It may be enough to simply caulk the seam after you assemble the cap. After you apply a new rubrail and seal it, it should be water tight.
Yacht Dr.
You will not have the time to Caulk and Rivet/bolt your deck in the time frame to make sure this is water tight..
I agree with undercaulking the hull/deck joint with 3m..but Im suggesting 3m 4000 ...
Just me though..
YD.
slogen
well the top is back on i used pl and 335 rivits. i broke two rivit guns in the process, and my hands are numb...............
drewpster
Not to rub it in, but if you have a compressor a air rivet gun is the real ticket. I almost recommend renting one to do the job given the number of rivets that have to be set. Sure makes the job easier.
slogen
i agree on the air rivit gun i was going to use one but all the rental stores around here didnt have them and i didnt want to wait so i bit the bullet an did it hand held way. ,boy are my hands bruised today
Outsider
Now caulk the joint before re-installing the rub rail and you're good to go ... ;)
slogen
should i calk it before or after i paint the boat
Outsider
Before if you use caulk that can't be painted, after if you use paintable stuff, doesn't matter if you don't paint under the rub rail ... ;)
ThumbPkr
My hull (Jetflite) had a thin foam tape with adhesive on one side.I used 3M electrical tape when I put it back together.The joint on mine was screwed together with stainless steel screws into a wood backing strip.Ron G
