will 888 drive fit a 260
biggjimm
My lower unit on my 260 Mercruiser is cracked & while looking for a replacement locally I ran across an old timer with a 888 drive off of a 302 Ford.
How much of the drive is interchangeable with my 260?
Just the cases?
Everything except the input shaft?
Nothing at all?
Different gear ratios?
Thanks guys
Jim
biggjimm
I called Mercruiser once I found a good phone number & they said as long as his 888 is a MC-1 drive like my 260 then it will work.
The gear ratio might be different but he said other than that I should be good to go.
It looks like overhauling the lower unit is going on my "winter project" list. Along with new center dump exhaust manifolds & risers, a silent choice exhaust system, & a new carburetor as well as re-building the sun deck/ engine cover & whatever else I run into.
Thanks. Jim
Ayuh,.... Go for it, they're the exact same drive,....
Both are MC-1s with 1.50:1 gear ratio, with the same input shafts,....
Only difference is the stickers stuck on 'em,....
Matter of fact, they'll also swap onto an Alpha 1 drive transom assembly,....
biggjimm
That's what I found, stickers are different, that's all.
I met this ol' timer at the campground over the weekend & he tells me about his old boat that he junked out but said he kept the "mercruiser piece" that goes in the back.
So when I drive over to his farm to look at it yesterday I find they cut the transom with a sawzall around that "mercruiser piece" & it's all sitting there bolted to a pallet. Engine & all. From pulleys to prop, the whole works. I told him all I really needed was the lower unit & I'd give him $100 for it. He says, well that's seems fair enough but you have to take the whole thing.
So I've got a little 302 that's clean as a whistle for sale.
They winterized it just like they did every winter & it's been in a heated garage since they pulled it out 2 yrs ago. And they are farmers so all maintenance was performed like clockwork & all parts came from the local Napa store.
I usually don't get those "good" deals like that but as they say even a blind squirrel finds a nut every now & then.
Thanks guys.
Jim
