will grease soften rubber?
DXN
I check over my bellows regularly, so I know there was no previous damage. When I greased everything some squeezed out and got on the bellows. After 2 trips I noticed the grease spots a little chafed. The rubber is very soft where the grease was and I could probably punch through it with a small stick. I used generic marine grease from O'Rylie's.
Re: will grease soften rubber?
yes grease which is oil mixed with a thickening agent does not play well with rubber. Not all rubber is made the same way with the same additives so some are affected worse that others the same as different brands of grease may react differently.
smokeonthewater
the INSIDE of the drive shaft bellows is very often heavily coated with grease slung from the u joints and gimbal bearing with no ill effects
the grease SHOULD not hurt the bellows at all... I suggest that maybe the bellows are just old and need replaced (should be replaced every few years)... possibly the grease created a clean spot by softening some oxidized rubber???
DXN
Ahhh I think your on to it smoke. The rest of the bellows is a little stiff feeling. And I was thinking they didn't have allot of life left, that's why I check them so often.
Thanks this makes sense now.
smokeonthewater
if that's be the case then go ahead and replace em BEFORE they sink your boat.
Texasmark
General Characteristics of Common Polymers from The Rubber Group
This is a thread about Neoprene rubber and if you read the comments at the bottom of that column you will get your answer. I would assume that any rubber product that is used in a marine environment would be of silicon or neoprene for the reasons stated. It's been many years since I had an I/O and changed out the bellows so I can't say much about it; other than it was one !@#$%^ of a job.
Mark
