will it fit
slate1234
Hi all, just woudering if a 1993 15hp lower leg will fit onto a 2000 model both short shaft.
Thanks
flyingscott
If they are both 2 strks I believe they will best bet would be to compare them
slate1234
the problem is mine is letting in water and there is on on fleebay quite cheep.
slate1234
I was thinking that but there would be a lot of questions being asked on here, I was going to carry on using it and change all the seals this winter as a project
If it is in good shape it will bolt right on.---Exact same units if 2 stroke.
