will my 1977 mercury 85hp prop fit on my 1985 merc 115hp
vadigger
my 85hp went bad and got a 115 without a prop. i just bought the prop and usedit twice. will it fit my 115?
Texasmark
Re: will my 1977 mercury 85hp prop fit on my 1985 merc 115hp
Try it. '77 and '85 should be running the same gearbox with maybe different gear ratio's but other than that should be a piece of cake. The '85 may be running a 2.3:1 whereas the 115 a 2:1. That difference will only show up in how much pitch you need to do a certain job. The prop shafts, clearances and all should be the same.
If it has a lot of pitch, you may have to change your trim tab and run the narrow one. On my current prop, I have had to trim the leading edge of my narrow trim tab to give it room to turn, but it works fine.
Mark
vadigger
it bolted right on. that saves me a couple hundred dollars. thanks
