Will prop from OMC outdrive fit Alpha one?
Scaaty
Re: Will prop from OMC outdrive fit Alpha one?
I doubt it about 99%
quote:<br />--------------------------------------------------------------------------------<br />Will a prop from an OMC outdrive fit on an Alpha 1? <br />--------------------------------------------------------------------------------<br /><br />Depending on the Year of the OMC,<br />Yes............<br />But,<br />A Merc. Prop, will Not fit on the same OMCs.......<br />Spline Depth is Different..........
Scaaty
Then again maybe 50% (learn something everyday!)
