will this prop fit
stubbsboogie
Hey guys I have a question.
I have just acquired a 14.25x21p viper stainless steel propeller.
I was looking on the web to see what I had, it seems these are 4 evinrude. My question is will it fit on my mercruiser drive? I know nothing about it other than it is in great shape.
I have been wanting a ss prop. It would be really cool since it was essentially free.
Thanks guys
Re: will this prop fit
Ayuh,... With the proper thrust hub, Yes, it should...
stubbsboogie
Thanks Bond-o!
Now how do I find out what thrust hub I will need to get?
I am super stoked! Does anyone know anything about viper props?
vicman
I bought a Mercury High Five 19p last summer. It will almost snatch your arms off for pulling. Turns out, it is no good for top end. Max revs were at about 38 mph and still had alot of throttle left. I was afraid if someone else drove the boat, they would'nt be watching for high RPMS. In the fall, someone at work had a 21p stainless that came with a boat they bought and did'nt want it. As it turns out, the 21p still has decent torque and better top end. If you can get a hub, you will probably be happy with this prop.
Vic
stubbsboogie
this is more of a bump than anything else.
Can I get the hub through I boats or do I have to contact Viper?
Thanks guys
Vic did you ever get the issues worked out with the Smart Tabs?
Ayuh,... Have you tried whatever thrust washer came with it,..??
How about whatever is with yer old prop,..??
