Will this prop work (3.0 L mercruiser)
Gryphon
I have done my searches and used the prop selector tool. Before I buy a new prop I thought I would run it by here first.
Currently @ WOT
RPM 4450
Mercruiser 3.0L
2008 Discovery 195
21" prop 3 blade aluminum
Need something better for skiing/wakeboarding etc.
Would an 18" 4 blade aluminum work or would it have too high of RPM?
Doing my own calcs
drop of 3" = +600 RPM
change from 3 to 4 blade = -150
New WOT to be ~4900 which I do realize is slightly over the reccomended RPM. What have others found as I am sure with all the 3.0L in use someone must have tried this in a semi similar situation.
Also I have SX smart tabs to put on, do they effect RPM at all. I guess I should install them prior to buying a new prop but I will be in the states this weekend and well things are cheaper there and would like to get one this weekend.
Thanks,
Tail_Gunner
Re: Will this prop work (3.0 L mercruiser)
That should be spot on..Good job of reading you way thourgh it..;)
Gryphon
Thanks, question really is I guess, Is 100-150 RPM over the proper range ok? Or is it a strict limit to adhere to?
Ayuh,... That's the job of your righthand...
You don't want to run across the lake Hammer down at 5 Grand...
A few seconds wound Too tight is 1 thing,... A few Minutes is another story...
MikDee
Banned
Currently @ WOT
RPM 4450
Mercruiser 3.0L
2008 Discovery 195
Doing my own calcs
Thanks,
Theoretically, just going to a 4blade prop 2" less in pitch like a 19" pitch will net you approx. the same 4450rpm, 1" less pitch would give you about 200rpm more, so I doubt you're going to reach 4900rpm, but that's my opinion.
Gryphon
If I was to go to a Mercury High 5, would most reccommend a 19" or could I get away with a 17"?
Thanks
