Will this work?
Re: Will this work?
Looks like it should work.<br /><br />Non thru hub exhaust lower unit.<br />Obviously cleaned up and repainted.<br />Expect to have to install new seals and a waterpump.<br /><br />Don't buy one from the seller in Texas, trouble !!
jippie98
Re: Will this work?
I had water in mine this past summer....Figure it is cheaper to get a new unit than have the pros look at it and then tell me it will be $500 plus parts or $200 in labor to tell me I need a new unit. how hard is it to complete a re-seal kit on these lower units? If I let the pros deal with it, what do you think they will charge? Thanks
timmathis
Re: Will this work?
Not hard at all, you sure will save alot if you do it yourself. You will need a manual.
