winterizing 260 mercruiser
kenthrussell
hi everyone and alas summer has come to an end......can someone tell me the proper way to winterze my I/O<br />it is a 260 mercruiser ........have done many outboards but this is my first I/O thanks
flashback
Re: winterizing 260 mercruiser
do a search on winterizing, you will find tons of good ideas........
Trent
Depends on your setup.. Make sure to drain risers, manafolds, block, transmission cooler (if equipped). Drain and refill outdrive. Change engine oil. Some people like to fill system with antifreeze/water mix.
