Winterizing Bilge Pump
RV Sam
Can I "assume" as long as there isn't any dips in the discharge hose and no water in bilge, my bilge pumps are winterized ? Guess I'm asking if a bilge pump keeps a head ? Thanks.
Re: Winterizing Bilge Pump
Nope,... It shouldn't.... Welcome Aboard....
5150abf
If the bilge is dry just hit the switch for a couple seconds and it should clear the hose but other than that you should be fine.
