winterizing twin 471's (detriot)
reefrunner7
Taking the luna sea to Kent island for the winter anyone have any tips for winterizing her detriots, I will have power and a heater down in engine room but if power goes out? Just be the raw water side I would imagine
Ned L
Re: winterizing twin 471's (detriot)
Yep, change the oil & filters, and run antifreeze through the raw water side till it comes out the exhaust and that should do it.
reefrunner7
The pink type antifreeze I would imagine right? wondering how to ingest the antifreeze through the system? Close seacocks and unhook the intake hose? put it into a bucket of antifreeze and turn the motor over? just guessing
Grub54891
Drain all water from the freshwater side of the engine first. Hook up your -100 antifreeze jug to the seawater pickup hose and run it till you get a good blue out the exhaust. Done! I always test what came out the exhaust with a refractometer just to be shure.
Grub
