Wiring amp kit..help!
Baylinercaptain90
I can wire a system in a car..wondering what yall,do for running the power cable through the engine bay to the aft cabin...this could be a stupid question can i ground the wire to a ground nut from an electric outlet?
90 Bayliner ciera
90 bayliner ciera.
If the outlet is a 120VAC outlet then NO
AC and DC circuits shall be kept seperated. Only thing that ties grounds anywhere near together is through a galvanic isolator. Run a separate ground cable to a buss bar
