Wiring Diagram
oxmax360
Does anyone have a wiring diagram for a 1980's 25 hp mercury tiller handle ele. start, any info would be helpful thanks.
Fun Times
Re: Wiring Diagram
Most of the mercury service manuals have been taken off line so this is pretty difficult to come up with now at no charge.
Bout the only thing you could do is post the serial number so maybe someone would be able to find the correct service manual part number for you and either let you know where to find it the cheapest with a google search or maybe by chance someone has it and will recognize the manual by part number.
Hope this helps, Good luck.
Charlie61
Re: Wiring Diagram
you may try tradebit.com they have many mercury manual you can down load for only $5.00 good luck
windy5849
Re: Wiring Diagram
Click the image a few times to make it larger.
