Wiring Seablaze underwater lights
jt1313
New to the forum and have a question regarding wiring 4 Seablaze Quattro underwater lights. I run each one to its own post on a dedicated blue-sea fuse box with each one having its own 3 amp breaker (which is suggested by Seablaze) and plan on switching the fuse box with a 20 amp rocker switch with its own push breaker at the switch. My question is what fuse and wiring gauge to and from the switch. Thanks for any help you can offer. Jt
Welcome
With each being on a separate fuse/breaker using 16awg would be enough in most cases. Depends on the total length of wire needed.
The 20amp main use 14awg assuming it will be a short distance
jt1313
Welcome
Thanks. This makes things clearer.
