wondering...
john crowe
why is everyone so down on OMC? Are the OMC 3.0 solid engines?
whats the issue with OMC over all?
stevieray
Re: wondering...
Never had one - this info is mostly scuttlebutt I've heard over the years. Mainly it's beacuse they are no longer in business. Parts available for them are used (e-bay type) or new aftermarket - no direct factory support. Mechanics who know how to work on them are rare.
All makes have some skeletons in their closets - when somebody finds one, they generally remember that above all else.
Fishermark
Re: wondering...
The issue is with their outdrives - not their engines. The 3 liter is a fine engine. The outdrive is obsolete and most mechanics will not work on them.
Scaaty
Re: wondering...
Yep, outdrives were/are/always will be junk..
Coors
Re: wondering...
So, I have a junker 1988 model OMC? It pushes a 21' in the upper 40 mph....and all it needs is the normal maintainence.
Coors
Re: wondering...
Used parts, NEW PARTS are availiable, and the are easier to work on. (hold on; here we go...).
Re: wondering...
Ayuh,......... It's got Nothing to do with the Motors,.... Most are Chevies anyways......
It's the Drives,+ All the marine parts that OMC hung on the Chevy motors that's the Problem.........
Scaaty's Right,........
Except for the short run of Volvos they used just before they went Under,......
OMC's have Always been Less than Ideal..............
john crowe
Re: wondering...
then whats the problems with the OD? what is the most perfect or desired engine/OD combo?
Gary H NC
Re: wondering...
Well,my OMC Cobra has been a good drive.If i ever buy another I/O boat it will have a Volvo drive pushed by a GM engine..
Re: wondering...
A Chevy based engine,+ Either a Volvo or Mercruiser drive.......
Chevies are the Most Common motors,+ Mercruisers are the Most Common drives......
Commonality tends to Lower Prices of Parts,.... Especially Used Parts......
