Won't start?
sethjon
My son just got 96 boat with a VP 5.0FLPNCS and cobra SX OD. He tried it yesterday and ran for a while and restarted several times. Finally it came to a stop and would not start. After looking at it, I put in new plugs and water separator and also a new impeller just to be safe. Threw a little gas down the carb and it started but only for a few seconds. Does changing the separator need to fill up meaning the engine needs to stay started longer or could it be something else. My second guess would be a carb problem. Any ideas would be greatly appreciated. Thanks in advance for any help. I should also say that when he first brought it home it started up fine and sounded great for an old boat.
Re: Won't start?
Threw a little gas down the carb and it started but onl;y for a few seconds. Does changing the seperator need to fill up meaning the engine needs to stay started longer or could it be something else. My second guess would be a carb problem.
Ayuh,.... It could be the carb, or the fuel pump, or a restriction in the tank...
You could try pre-fillin' the filter...
sethjon
Re: Won't start?
Thanks for come back Bond-o. I did think of those things too but it started fine when he first got it. I was thinking air in the line. Will try later to pull it off and fill it with gas. Will let you know.
sethjon
Re: Won't start?
Hey bond -o...just filled the water separator and nothing. The only other thing I thought of was diconnect the fuel from both sides and I thought I would see lots of gas spilling out, but nothing. Could a fuel filter go bad all of a sudden without any warning? Anything else I should try to check before taking in for an expensive bill?
Re: Won't start?
Ayuh,.... The fuel tank needs suction to over come the anti-siphon valve...
That's why gas don't just run into the bilge when ya change the filter...
The Tank's pick-up might be what's Plugged up...
Fuel filters don't go Bad, they get fulla Crud, 'n water....
sethjon
Re: Won't start?
I mistyped. I meant does a fuel pump go bad all of a sudden. If the pick up is clogged, does that mean pulling the tank out and if not, where is it?
