WOT for 19" vs. 21" Pitch for 5.7L Merc
neikrk6
I have a 1996 Conquest Bowrider with a Merc 5.7L 260hp I/O. Last weekend I ran 55 mph (GPS) at 5500 RPM. Is this above the recomended WOT rating for this engine? I would like to upgrade from a 19" x 14 3/4" SS 3 blade prop to a 21" with same diameter. Is this ok or should I look for a larger diameter or 4 blade prop? It makes me a little nervous for a V8 engine to run at that high RPM. Please advise...
Tail_Gunner
Re: WOT for 19" vs. 21" Pitch for 5.7L Merc
Get some good advise and go see Bond-o and get his opinion on the rpm range for that engine Or Don, differnet people but very sound advice pay attention to them both.
4800 should be about the max rpm for that engine, 4600 if it is pre vortec
Ayuh,..........
The 21" might get you in there,...... Or possibly a 23"......
But you Do want to shoot for 4600/ 4800rpms as your WOT rpms..........
Silvertip
Verify the tach before spending bucks on a prop.
