WOT timing value on a 90hp johnson?
roonie
Can someone tell me the WOT on a1996
90 hp johnson crossflow please.my manual won't be here for 2 weeks min.
It's bored .30...not sure if that matters.im doing the joe reeves timing method
WOT Range for a 96 90hp Crossflow is 4500-5500. The 90 makes its Peak Hp at about 4700-4800rpm
Isn't there a Sticker on the Airbox that states WOT Timing?
28 BTDC was common on the 90hp. However, setting that at cranking speeds could yield a different value when running at High Rpm due to the Characteristic of some Electronic Ignition Systems. Best to wait for the Factory Manual
As for the Joe Reeves Method... I prefer the Factory Method. so wait for the Factory Manual, it is only 2 weeks away
A 0.030" Overbore, isn't going to affect anything. I doubt that adds up to extra 2 cubic inches, might give an extra 1/2 hp,
roonie
thank you..much appreciated.
Im going to have to resort to the JR method as our walleye bite is pretty hot right now. Here today gone tomorrow type lake
Careful, your motor can also be here today, gone tomorrow...
That’s not a joke. Play it safe and don’t run wot until the manual arrives. Pre ignition can wreak havoc is short time. Be gentle with her if you must go.
