Wrong plugs causing stalling in Evinrude 115 FICHT?
rustyscrew
Evinrude 115Hp 1999 FICHT (E115fpxeec)
My mechanic put Champion 7112 plugs in.
It runs ok at idle, but stalls when I advance the throttle (disengaged). If I punch it past the stall point it will rev up and run fine. If I return the throttle quickly to idle position, it will come back and idle fine, but if I move slowly through that range, it stalls. So basically there is a dead spot where it stalls that is just above idle.
I noticed that the plugs look wrong to me. They put in Champion 7112 plugs and I think they should be QC12PEP. I know these engines are sensitive to gap, index and type so I am wondering if this could be the problem.
These guys were supposed to be the go to Evinrude mechanics for the San Francisco bay area, so I am doubting myself wondering whether I am missing something. Of course I have been cleaning up after their mistakes in other areas too.
Before I go throwing more money and willy nilly replacing plugs, curious if anyone has some insight on whether these are really the wrong plugs and whether the y could be the sole source of my stalling problem.
thanks
aerobat
Re: Wrong plugs causing stalling in Evinrude 115 FICHT?
there are many wrong things here...
when you have the old style not pinned cylinderhead ( by factory you should have with a pre 2000 V4 ) the manual calls for 7712 (not 7112!!) and if your engine was someday improved with pinned heads it calls for XC12PEPB . QC12PEP are only for the big bore 90deg V6 engines and in any case also wrong.
verify if you have pinned heads or not and verify if you only made a typo or have the wrong plugs installed in any case.
this is a great article with veryfying pinned heads, correctly indexing the plugs and a table of the correct plugs for a given appication :
http://www.boatsetup.com/PlgIndex.pdf
cheers
