Y Pipe Corroded!
djmakko1
Hi folks: I have a 86 Chris-Craft 5.7 alpha 1
Y pipe was bursting water dismount the motor and find the Y pipe corroded , any ideas why this happened? do I have any other problems. Thanks for your help.
nola mike
How did your exhaust shutters look? The old one piece design would fall off and lodge down there, eventually eating a hole.
do you boat in salt water?
since the part was designed to last 15 years and its going on 35 years, not bad actually.
Bt Doctur
excessive water in the bilge . I install a small 500gph at the very stern and turn it on as I power up.
GA_Boater
Had the same thought, BT. It looks like the corrosion is external judging by the stuff around the hole.
djmakko1
Ive accidentally put in in the water without the plug about 2 years ago that is the only time the bilge had water , you think that could've cause it? is in salt water btw.
Lou C
That I doubt but you never know how good the grade of aluminum was that they used. My '88 Cobra has sat with salt water in the Y pipe all season on the mooring approx. 15 years! Might have been a casting flaw/air bubble, weak spot that just corroded through as the rest of it does not look bad. Not sure if this helped but I always filled the exhaust with AF with corrosion inhibitors each winterization yes a lot of it runs out after the manis are full but maybe enough remains at the bottom to help.
tank1949
Mine "cancered" out just like yours due to rotten transom which allowed salt water to continuously coat y pipe and inner transom assembly. Former owner may have never flushed/rinsed with fresh h20 either. If 1986, I'd check for rot. If rot, the work really begins. I am putting my 86 SR together and thank God I labeled all wires. Good luck! Start searching ebay for freshwater used y pipe.
djmakko1
I’d definitely try that out on every winterization , also checked for rot and is not present looks solid ,
pyrotek
Do you commonly have some water in the bilge? Like enough the bilge comes on once a week? Common issue is the steering pin leaks at the top and the water seeps down and drips off the bottom of the Y-pipe. Every Y-pipe I have seen has some corrosion exactly at the bottom two mount points.
djmakko1
Not likely I have water in the bilge , but after removing the Y pipe and check for possible leaks I found some corrosion next to the trim pump manifold where the two hoses connect to , my believe is the there was a small intrusion there enough to corrode the Y pipe on the long run. seal replaced only waiting for the new Y pipe , and also installed a second bilge pump just in case.
CamaroMan
if the metal is powdery or you can tap pieces it away with light taps from a hammer replace it - its ready to get swapped, do it now with motor out!
djmakko1
its done , had to replace the gasket on the trims manifold water was sitting there in that pocket between the y pipe and manifold hose exit . changed flappers /still in good condition but since its out better doit now.
