Y-Pipe Woes....
Haut Medoc
I have a leak somewhere way down, ( it looks like the Y pipe, but I can't be sure until I pull the engine)....
I have the Y-pipe, but I can't seem to locate the part # for the 3 rubber o-rings that mate it to the transom plate....
It is a '73 model 888 s/n 3465919.....
Piece of crap only lasted 37 years in salt water!......:rolleyes:
Perhaps the oracle can help?......:D
zbnutcase
Re: Y-Pipe Woes....
Only 37 years???? My god, you need to file a warranty claim!
Re: Y-Pipe Woes....
Hey Haut,....
Go to an industrial supply/ Hyd. shop,+ find whatever Fits... It's Just an Oring ain't they,..??
Slicktified
Re: Y-Pipe Woes....
Here's a link to a parts diagram CLICK HERE
Looks like parts #19 & #20
Part#25-20863 for the large o-ring
Part#25-20863 each for the two small o-rings
Hope this helps out.
Also not sure if you would have to pull the engine or not to replace the y-pipe. I put the exhaust shutters (both sides) in mine the other day with out having to, even though the manuals said I would have to. I didn't really look to see if there was room to get the y-pipe out because I wasn't going that deep in to it.
Haut Medoc
Re: Y-Pipe Woes....
Thanks!......:)
Kainon
Re: Y-Pipe Woes....
unfortuneatley, yea.. you do need to pull the engine, there's 3 bolts and just not enough room, unless your Tom Thumb.
Haut Medoc
Re: Y-Pipe Woes....
:mad::mad::mad:
Kainon
Re: Y-Pipe Woes....
that's too bad !!!.. they do sell bolt kits through Sierra Marine !!!
