Yamaha 60hp FETO Autolube Question
vandad
Hi Guys,
I have recently purchased a boat which has an oil injection system (Autolube). Previousely I owned an engine which I had to pre-mix oil+fuel 50:1 ratio.
I am a bit curious about the oil consumption on Autolube system. I filled the oil tank and after burning about 15ltr of Petrol it has only consumed about 100cc.
If I was going to pre-mix, it would have burnt at least 300cc...?
So does anyone happen to know the rough oil consumption rate on Autolube?
Thanks,
99yam40
Re: Yamaha 60hp FETO Autolube Question
all depend on the RPM it is run at
and if it is functioning properly
vandad
Well, this is exactly my question! how do I find out whether my Autolube is working or not! I am quite scared of operating the boat as I don't want to cause any damage...
Any suggestion?
99yam40
Your Yamaha service manual should give the procedure and specs for testing and measuring in cc or ml the oil output at a given RPM over a specified time period.
Just make sure you are running on a premix small tank and the mix has made it through the system before disconnecting the oil line to measure.
