matt167
- Joined
- Sep 27, 2012
- Messages
- 4,394
My new boat ( 1989 Sylvan offshore ) came with a 2002 Yamaha 9.9 ( T9.9 ELRA high thrust ). Couple issues. It is pumping water but not as good as it should. I put a new pump in it and the pump impeller that was in it was good. The passage is clear. Also it won’t start unless it’s manually choked briefly so I don’t think the primer system is working. I think it’s a pretty high hour motor. Debating repair vs replacement as 9.9’s aren’t terribly expensive in boat terms
