Yamaha 90sho, 2019, oil alarm on. Very low hours.
pettitt
Idling and ran upon sand bar. Turn engine off, raise motor. Trolling motor down and pull off sandbar, couple min to do this, lower motor. Attempt to start and get oil light and alarm and engine dosent start. I toll back ( over an hour ) to ramp, tried a couple times with same result. Boat on trailer and pull cover. Oil perfect an clean. Whats happened?
boscoe99
What are you seeing that is telling you that it is the low oil alarm? Is it a Yamaha tachometer?
boscoe99
When you say that the motor does not start, are you saying that it cranks normally but just does not start up?
Or is the situation that it is not cranking?
