Yamaha prop nut kit & torque
OtterRidge
Does anyone know what the Yamaha part no. is for a prop nut kit for a 2023 F60LB 60 hp outboard and what the normal torque would be for that size engine? The manual says 25 ft. pounds but when I removed the aluminum prop and replaced it with a stainless steel one it sure didn't seem to be that tight.
25 ft# is correct
Is the prop the correct prop and hub kit?
OtterRidge
Yes it is a Yamaha G12, 10.5 x 12 13 spline. The hub kit is the one that came with the motor, was looking for the part no.as to order a spare one.
