Yamaha's View and History on Gasoline....
This is why Yamaha created Ringfree A.K.A. Quickleen...
99yam40
Re: Yamaha's View and History on Gasoline....
Jeff it would be a good idea to learn how to post things where others can read the whole post without having to look at different threads and move to the bottom of the post to move over to the side not showing up on the page.
Or is it I just do not have my computer set up properly?
Well I just readjusted my screen and I can now see all across the page, but the print is small and hard to read for these old eyes, but you could just replay to your original post and add the rest instead of starting a new thread;)
robert graham
Jeff, Thanks for all the information. Yamaha contracted the Oronite Additives division of Chevron to develop Ringfree specifically to address the carbon problems on piston rings and ring grooves, and It's worked very well in my motor. Some research on Oronite Additives shows that they pretty much wrote the book on many types of fuel additives, including gasoline outboard motors.
No it is just the best way I have found to post a snap shot of what is on my screen. The information is obtained in PDF format from the tech guide. I do not have a way to save/post just a certain portion of the document without a long drawn out process of online file conversion. The program takes a "print screen" picture and magnafies it. So the actual size being legible is made a little harder to read. It is better for just 1 picture references. But with reading the whole document you can anchor your cursor on the page and use the directional arrow keys left and right to move the document for ease of reading
brentjsimm
Do you have a link? My work blocks screenshots on this site for some reason.
It is a series of links of about 9 different ones. If you go up to my original post and "reply with quote" the websites will be available for view in the source form. Just copy and paste the http--(through)--.com and put it in the adress bar and you will be able to see each link posted on iboats. It will take a while or you can navigate from my folder on screencast
http://www.screencast.com/users/jeffersondodson561/folders/Jing
