Year of my mercruiser
Miguel847
Hello, I'm trying to find out what year is my mercruiser engine. I have tried looking up with the serial umber on the upper unit and the engine itself, but no luck. Can anyone please tell me how I can find out? Thanks in advance. Info below:
Engine serial no. 6913871
Upper unit ser no. 6920187
carholme
Re: Year of my mercruiser
MERCRUISER - (MC1 H.P. (1985 ))
Serial No: 06913871 Model No: 00011005
Gerry
Miguel847
Thanks Gerry! How did you find that info? Does it matter what the upper unit serial number is? Or do you just go by engine serial number.
carholme
Just used the engine s/n. See my PM to you with the parts listing.
Gerry
Miguel847
Got it, thanks. One question since I can't find it on the website, is this an alpha 1?
Fun Times
It appears you have these numbers backwards!
Serial number 06920187 is your engine #, MERCRUISER - (140 H.P. (1985 ))
Serial No: 06920187 Model No: 01409005.
MERCRUISER 140
PARTS CATALOG
90-41261 - 120 H.P./2.5L140 H.P./3.0L R/MR/ALPHA
Serial number 06913871 is your drive #, MERCRUISER - (1-MR-(mercruiser redesigned), (1985 ))
MERCRUISER MC1 drive
PARTS CATALOG
90-99964 - R/MR ALPHA ONE STERNDRIVE
Miguel847
Awesome! Thanks for the info, greatly appreciated
achris
More fish than mountain goat
MERCRUISER 140
PARTS CATALOG
Serial number 06913871 is your drive #, MERCRUISER - (MC 1 (1985 ))
PARTS CATALOG
Hey FT, wouldn't 1985 make it an 'MR'?
achris
Hey FT,
Could you clear some space in your message folder. I would like to send you a PM.... Cheers.
Miguel847
A lot of great info here, but what's the difference between an "MR" and "MC"?
achris
MC-1 was 1963 (about) to 1982. The MR shares very little with the MC-1, not even housings. Same water pump impeller and housing, same water pocket cover, same seals. Some of the same bearings, none of the same gears. Even the gear ratios changed slightly. Basic shape and function are the same.
Download this Mercruiser drive history... Plenty of good info there.
Mercruiser Alpha ID and History - Download - 4shared - Don S
Chris.......
