You Guys Inspired Me!!!!
GA_Boater
Re: You Guys Inspired Me!!!!
Black Mercs look good hangin' off the back of a Starcraft. :D. I an not biased. Much. :lol:
crankbait cowboy
that merc will work nicely on your tinner, good to see ya back at it
classiccat
Great find! The motor & trailer are tailor-made for your boat...I dig those retro hub caps! :thumb:
cpdchap
Bluefin now I am offended......I just rebuilt the other trailer and painted it!"..........the funny thing is your right it's almost the same trailer, if only I would have found all this a couple months ago, oh well.
cpdchap
Hey guys quick question???? When I took my motor off there was an extra piece of plywood mounted outside the transom. Is this for extra support, or protection of the aluminum from the mount digging in???? I have no problem putting a piece back on, I just want to completely understand................the piece I took off was 1/2" thick untreated plywood.
lakelover
It's not needed, but protects the surface (unless it's PT wood!). Some people make them from plastic cutting board material -HDPE- or aluminum etc.
cpdchap
lakelover, Thanks, that is kind of what I thought but wanted to make sure. I was actually thinking aluminum but a piece of -HDPE- sounds even better. Thanks again.
InMotion
CP --- really not needed to be totally honest.... kinda protects the paint from getting scuffed up when mounting the motor is all that it really does. I was "convinced" :) not to put one on the last 2 boats and totally agree with that theory. I put a thin layer of aluminum on the Jupiter just to cover up the cruddy aluminum on the boat.
As always... it really is your choice... but the plastic route or a piece of aluminum would be my vote as well!
Keep it rollin' man....
J.
ezmobee
I personally hate them and have deleted that piece from both my restores. You don't see those plates on any newer boats. In my opinion it only promotes possible future leaks especially if it's wood and the motor forces compress it a bit loosening up the fasteners.
cpdchap
IM and Ezmobee Thank you both for the input I think we will officially delete that little piece from the restore. Definitely seems more solid without it.
cpdchap
So today was semi productive, It took about two hours to get back in the groove and figure out where I was and what actually was next...........So I finished all the front deck work and cut out new side panels, I am headed to the upholstery guy in the morning to get material ordered. Before any upholstery is done I am covering the front area with nautelex so that when fishing we can take the cushions out and still have coverage.
I also had forgot about a crack in my transom brace so on the way back from the upholstery guy I will stop at the welder and see if we can get it beefed up and fixed. I was thinking to add a piece of 1/4 inch flat stock up the face of the brace where the holes are, to strengthen it up. Anyone else beefed up the transom brace before?
Also I received my transom caps came in today and kudos to "MichealP" they look great.
GA_Boater
Plenty of repaired knee braces here, CP. I know BlueFin did a heck of a job on his.
cpdchap
I will sneak over to his thread and check it out, Thanks GA
GA_Boater
BF has set the standard for tin work in the drydock. He has salvaged what most of us would have turned into beer cans. It hasn't been easy.
cpdchap
I just cruised through his thread and think I will copy the knee brace repair..........easier then welding:)
dozerII
Making good progress cp. Knee brace problems are a common occurrence, and BF's method of repair is second to none.
barato2
and quite possibly stouter, given that welding these crocks seems to risk inducing some other issues
cpdchap
Met with the upholstery guy today and ordered the material, I will drop off the SS monday for him to do the work.....OUCH! little more than I expected but once I thought about how much work it is I realized I probably wouldn't touch it for that much, so we go forward..........The other thoughts that cross your mind are " maybe I don't need to do it this nice" but since we have come this far I don't want to cut corners on the finish.......That's my whine session....
I did get the front plywood decks covered with Nautelex....I glued the bottoms first with S-18 and then stapled the edges then cut the top piece big enough to wrap underneath an 1 1/2 ......before I pulled it around though I ran a bead of adhesive caulk on the edge so water can't work it's way around to the wood. I also routed the front edge so it wouldn't have a wear point on the sharp edge.photo 1-2.JPGphoto 3-2.jpgphoto 4.JPGphoto 5.JPG
Starting another job tomorrow so we will probably be a little slow till the weakened.
dozerII
Nice job on the deck vinyl, that should not let water in for 40 or 50 years.
ezmobee
Real nice work on the front deck.
