- Joined
- Jul 18, 2011
- Messages
- 19,169
Another progress update . . .
I added a second layer of fiberglass (2415 stitchmat in this case) to the planing surface (upside down 'V' shaped portion, Joe).
Don't tell anybody, but I used plastic drop cloth to cover the surface after it was wet-out and pulled it tight in all areas to give the stitchmat a smoother surface. It also helps avoid dry spots . . .
I'll be putting a final layer of 1708 on the 'V' shape, and more glass of various types on the transom and sides.
It seems like I have lots of cloth, but not enough resin . . . I may need to get another pail of it. The resin I'm getting in the 5-gallon pails is 'Advanced Coatings 13886 MVP - No Wax'. I ran it by the resin Guru ( ondarvr ) and he thought it was pretty good.
