I/O (Sterndrive) Conversion to Outboards
The last drain I installed I used a curved syringe to soak the wood with penetrating epoxy and installed the sleeve with 5200 in hopes it would remain a wee bit flexible. So far it was been good as far as I know anyway.
Pmt133
Silverton also installed their garboards on the bottom of the hull, installed from the inside much like how Scott showed. Imo, that's the way I'd do it.
Agreed especially if there are no engines in there anymore. Had an old penn yann years ago (30+) that had it in the hull bottom was a PITA even with straight 6 ...
OK . . . thanks for the comments.
I'm more concerned about the weep hole (sleeve) that will be between the 2 pieces (hull & extension). I believe surrounding it in 5200, as mentioned may do the trick for longevity.
As for the garboard itself . . . I could go either way, but if on the bottom (of the keel), I'd want it to be recessed in case of a run-ground situation. . . . but where things are at, that train has left the station, unless I'd want to do a bunch of re-work. ( :cautious: )
Pmt133
Based on what I've seen with the current crop of 5200 I used... I wouldn't trust it to not shrink. I think Scott may have some choice things to say about it too. I switched back to boat life for stuff like that.
Splashwells . . .
A unique aspect of the design is that there are stringers directly in line where the engines will mount, as well as stringers to either side. Installing the splashwells seems to be a bit of a challenge given that here will be little/no access to the underside of the wells once they are installed. I also need to provide good access the the inside of the transom for engine mount installation.
My plan is to install the bottom 'plate of the splashwell onto the stringer and transom.
I could even give the bottom a slight angle towards one side where there would be a drain hole through the transom.
Then I would drape 3-4 layers of fiberglass over the whole area and allow it to take the shape of a splashwell.
Then I would need to have deck plates as access holes to do some tabbing on the underside, and to provide engine installation access.
Not sure if there are better ways of doing this, but open for ideas. . . :unsure:
BTW- My lifting hardware ('U' bolt) looked a little tired yesterday while I was lifting the E-B. I checked the rating on it (320 lbs !!! ooppps) so I got the larger bolts you see in the pictures. (560 lbs each)
Ted,
regarding the tube, get a bit of fiberglass tube and glass it in since you are bonding the pod to the hull anyway.
Im in agreement with @Pmt133 .... I cannot and will not support 3M sealants after the repeated failure of my boat which isnt used as often as it should. would hate to see a leak. So if you choose 3M... use at your own risk.
look here for alternatives. I suggest BoatLIFE LifeCaulk https://www.practical-sailor.com/boat-maintenance/marine-sealant-adhesion-tests
reminds me to write the follow up on the 3M failure with pictures, lot codes, etc.
Why not two drains, one in old boat vertical and one standard in the new section? I assume you will put a pump in both so that means a drain is appropriate there as well.
Also, is 4200 not more flexible than 5200? Or if want to join there is a silicone ive used a few times, gooey as sh.t but it is still flexible on my sunroom transom windows after 11 years, full southern sun exposure.
flashback
maybe install a vertical bulkhead at the forward end of the splash well space, in other words the aft of the extension becomes the splash well.
I don't know how this happened, but for some reason, I have no 1708 cloth left, and about 15 yds of 1808 . . . :unsure::cautious:
I thought I was using up 1808 like a bad boy . . . but maybe not. I'll just use the 1808 on a 45Ëš angle and call it good. :p
Odds and ends today . . .
  • Fixed some dry areas on the starboard side panel
  • Added the 5th layer of tabbing to the engine stringer/transom joint
  • Added stiffeners to the top plate 'wings'
Tomorrow will be transom finishing day . . .
Right now I am splitting time between the extension bracket and a couple of boat upholstery jobs that I have. (Repeat customers, hard to say no . . .🤪)
I've been meaning to add these stiffeners to the portion of the top plate that will extend out beyond the swim deck. I finally got them done.
Also ground out a dry spot on the starboard side panel and re-glassed it.
One more layer of glass on the transom, then I'll make the splash wells.
The current boat has an angled transom or swim deck?
Side note, your caulk storage system is so totally wrong....
you going to fill that pocket with foam and skin it?
This is for @redneck joe . . .
The extension bracket 'slides' under the swim deck to where the line is shown . . . So, there will be some 'walking/stepping' area beyond the swim deck when the engines are in a down position.
I glassed the stiffeners so if a fatty steps on the edge it will all be good. :LOL:
flashback
I'm gettin itchie just lookin at the pics.
I may have to revisit my weight estimate as well.
