My 84 4winns horizon 195 project.
Pmt133
Wow what a great job and so glad the pix are working again so we can see the finished product. About the noise I wonder if it’s the exhaust flappers; when I changed my exhaust from the one piece batwings to the 2 piece conventional exhaust the flappers did make a bit more noise at times which sounded like an engine knock just about drove me nuts. Finally found it with a mechanics stethoscope on the Y pipe…
It sounds like wailing a block of wood with a sledge once. Honestly maybe something floating in the water both times?
Lou C
Check the engine mounts; could the engine be shifting slightly under torque?
Lou C
I forgot does yours have the balance shaft or not? The pre balance shaft units came with pretty soft front engine mounts I know on mine if you watch closely you can actually see a slight up n down movement at idle speed. Even with the “even fire” crankshaft….
Pmt133
Congrats, looks great! Also nice job on how quickly you finished.
Finished is a stretch. I have a small punch list to take care of still. Bow rail fittings, cabin needs to be upholstered and resealing the windshield/rub rail. It's fine for now but still needs some stuff done. But that stuff was always going to be done at a later time.
todhunter
Canoeist
Congrats. You worked at an insane pace to get it done in only 68 days. Good luck on the upcoming SOTY competition!
Pmt133
68 working days. Figure over how many months but still, pretty incredible pace given some days I wasn't starting until 10 and calling it quits at 8 or so. I don't think I worked on it past 21:30 once. And that also counts days I only put in an hour or two and left. Any day I was there counted.
TripleJGraffis
Dang!!! This is awesome! Now this is progress! She's beautiful!!! Congrats on getting this far and so quickly!!! Can't wait until I've gotten this far!!!!
Pmt133
Managed to spend a few hours on the water today as well. She's running flawless. Wanted to get some prop testing data but my new prop requires a flat anode it seems.
Pmt133
So I haven't pulled the plug since my first launch. There is a puddle in the bilge and it's salty. Nothing major, maybe a cup but annoying none the less... Looks like I have some investigating to do. I am assuming it is from the engine at this moment in time.
Pmt133
Looks Like I have 2 leaks. 1 is my brand new water pump. :rolleyes: And the other is water coming out of the shift cable end on the linkage. Seems the shift shaft seal failed causing this... Will have to investigate further.
Pmt133
Aside from the couple of teething leaks, I've put about 30 hours on her since the splash. Friday, I ran out Barnegat inlet and then proceeded to run the 25 miles north offshore back into Manasquan inlet.
My punch list for now is:
  • Finish cabin upholstery
  • Fix that damn drip
  • update stereo
  • Reseal windshield (hopefully I can find the gaskets for the glass, it leaks bad)
  • Fix the horn
  • 3 inch risers minimum.
  • wax
Pretty light list all things considered. I think the best compliment I've gotten is that it doesn't look like I did anything. While that may seem insulting, the fact the floor is rock solid and everyone says it looks perfect, To me that is a success. To do something that drastic and have it go back perfectly that is. A friend let me keep it in a slip at the marina so it'll be there until early November. Hopefully another 30 hours gets put on it!
Pmt133
Oh, and also, I'm going to replace the platform on the boat with a teak one. To gut the current platform and recore it doesn't seem to pay. The gelcoat is worn and the time it would take could be better spent building a teak one, which would look very nice on this style boat.
Pmt133
I got the coolest response from a friend on the water today. I was running wide open toward him and he was cruising back. He goes to me "that thing looks badass coming toward you. Like a dart. Little chine walk, most the thing is out of the water, looks bad. ass."
I call that a success.
Pmt133
So I've started planning phase 2.... Couple of things on the punch list though some I may make a new thread for just for some better opinions... Also, since we had the photo glitch I may go through and do a condensed version of this thread with all the photos in the right place incase it helps anyone.
The list:
  • Pull engine and investigate transom leak (I know...)
  • Update stereo
For the cabin, I am curious everyones thoughts. I was planning on cleaning up the glass then doing thin headliner foam on the surfaces then going vinyl over that. I am having difficulty finding a marine thin line foam however I guess in the cabin regular auto foam would suffice.
The leak I am nearly positive is the Y-pipe and explains why it is worse when running but not on plane
Stereo, I am keeping the current head unit for now but doing a 2.1 setup and seeing how I like it. I may move to a 4.2 setup if I want more but I think It'll be more than enough as is.
Windshield is going to be nightmare fuel. Praying I don't damage the plastic trim.
eggs712
I bought a roll of 1/4" PE foam for the same purpose. It's a decent insulator, closed cell, and relatively inexpensive. I'm just using Dap Weldwood to glue it to the hull.
