My 84 4winns horizon 195 project.
briangcc
I'm going to lean on another hobby of mine...aquariums. Stay with me for one hot minute...
The lids to glass aquariums usually are glass, and have a plastic hinge. You can get that hinge in black or clear for various thickness glass. That's where I would look. It'll more than likely be narrower so you may want to replace the other side for a consistent look.
Pmt133
That's actually what I was looking for. And shower glass partitions.
Pmt133
So here's a question. Sealing the windshield to the hull. It appears to have been done originally with silicone or some sealant. I see now people use foam tape. I'm curious what all you all have done to seal/bed it to the hull.
todhunter
Canoeist
Man, I don't think mine had anything. Maaaaybe a thin foam strip. It definitely wasn't bedded or sealed.
MikeSchinlaub
I would suggest the foam strip. It'll dampen any vibrations and give a bit of shock absorption. If you do silicone, you'll just squish out pretty much all of it, and you'll hate it if you ever have to take the windshield back off.
Pmt133
I wanted to get the thread updated with all the pictures I couldn't upload in the middle there... So here goes.
7/24/24:
Got my continuous wrap of CSM in and over the side compartments.
As you can see, they tabbed nicely and I went about half way down the stringer. Completely encapsulating the deck again.
Bulk heads also glassed in.
7/29/24:
This was the plan to have the removable center hatch of the deck to pull the tank if need be. I also cleaned up the pass throughs for the fuel lines.
Adhering one side with PB...
While that was drying, I gelcoated the bilge.
Coat 2, pretty close match to the hull.
Test fitting the boards the deck gets screwed to.
Glassing in the panels to the hull structure. (I can say this now, they held 600lbs no issue.)
7/30/24:
Rebuilt and installed the gimbal assembly and dropped the fuel tank in its home.
Not a final install. Added some bracing front to back to help stabilize the tank.
Looking good.
Also looking good.
8/2/24:
Filling in the egged out bow eye holes, grinding the bow for the anchor shelf/well, adding boards for battery, blower and trim pump mounting.
Panels installed with thickened epoxy to hull and deck.
If you zoom in you can see the ground area for the bow eye backer and shelf/panel.
Tape over holes to keep epoxy from running out.
8/3/24:
Work on the bow eye backing and anchor well.
Cut the fuel tank hatch to fit first.
Test fitting the shelf...
This is how I choose to do the backing for the bow eye. I mixed some hairy PB and laid it down in the v notch.
I then floated in a strip of plywood.
Then a lay up of 1708 over it.
Then I did the same thing with a wider piece of plywood. Floated over PB then 2 layers of 1708. This is the middle of the second layup.
All done.
Tabbed in bottom and top the board is pitched to the front. I intend to add a small drain that runs out near the bow eye so the anchor well doesn't hold water. The original was level even when stopped.
The nearly complete bow eye backing. More substantial than what originally was there.
8/7/24:
Finishing the bow eye and compartment.
I test fit the cabin bulkhead for the V birth first. Looks alright.
Followed by drilling and bedding the bow eye in 5200.
This is my backing and support of the bow eye. If this pulls out, I deserved it honestly.
Sealing off the cabinet. I will install an access port on the front here should I need to get to the back of the bow eye. The wood also makes the anchor well a tub instead of being able to flow water behind the panel into the cabin... worked out nicely.
8/8/24
Cabin work...
Nothing earth shattering here... got the cabin bits done some and installed the new rack at the helm....
8/12/24:
Built the seat boxes.
The original I used to template. (very rotted)
The replacement. I made them a little taller and wider.
All done.
8/13/24:
Installing screw downs for the seats...
I glassed in these bosses so I can screw to them rather than the sealed deck. The black line represents where the box ends so I have room to move it around if need be.
Pmt133
8/16/24:
Test fitting all the cabin pieces:
Looked like something with the original bits installed...
Building all the trim pieces for the cabin...
Mock up looks good.
8/17/24:
Carpeted the seat boxes.
Again, not earth shattering....
8/18/24:
Gelcoated the cabin and finished carpeting trim pieces...
8/21/24:
Remote oil filter setup on the 4.3l
20240821_111203.jpg20240821_111225.jpg20240821_112241.jpg20240821_114553.jpg20240821_140101.jpg
8/22/24:
More rigging of the trim pump/blower.
Note the epoxied zip tie holders for no screw holes.
8/26/24:
Rigged the blower tubes and deck hatch.
Deck hatch installed
Blower tubes installed.
8/27/24:
Cleaned up to get ready for her to get out of the garage!
She's ready.
Pmt133
Found the photo from the maiden voyage last fall. I look very concerned. :LOL:
Pmt133
My new swim platform came in Friday. I've been too crazy with work to do anything with it though.
Pmt133
So today I'm addressing a few nagging things. I had old through transom screws that I drilled out and backfilled with marine-tex before installing the transom wood. Fast forward to after it was in the water for two months and that marine tex had bubbled out. It was now softened and felt like 5200 instead of marine tex. I have never had that happen before. So today I drilled that out and am going to rebackfill the holes. The wood was dry (luckily... as it should be) I also am installing my new transducer....
Note, those holes were filled from the inside then i just landed them smooth originally. Perhaps an issue or reaction with the old botto. Paint?
Anyway, here is the test fit of the new swim platform and comparison to the original...
Pmt133
Been a minute since my last update... so here it goes. This is what I've been working on the last few days.
Pulled the trim cushions out of the shed to finish them up first.
Next I cut a hole into my new fiberglass work. One of the most painful things I've done this whole project....20250626_151958.jpg
Then last night I started applying the headliner. Started on port then went to the starboard side. Yo can see my wrinkle the first go around...
I almost look like I know what I'm doing here....
Pretty sharp.
Pmt133
For today, I started by being a little weenie. It's around 90 out and the boat was in direct sun most of the morning. So I tossed my portable A/C unit in the boat and had it blowing moderately drier air in the cabin. Made it workable.
Next I got up half of the headliner before some savage storms blew threw.
The florescent underlighting is making it look much worse than it is but overall... came out really good. I have some finish trim work to take care of after it's all up... but for now it's looking good. More to come.
Lou C
Something special about a vintage boat restored to better than new…..
Pmt133
Hey all. I have a question. I'm going to be going through and filling in a couple scrapes on the bottom before I paint it. I also want to fill those couple of dents as well. What all would you use? I was thinking the 3m high strength or regular filler would work. I don't know that I'd trust just a thickened poly for that. I do still have some epoxy. I guess I could thicken and fare that for free and make it work too.
