No spark 55 HP Evinrude triumph 1969
Did you line up the key on the rotor with notch in the crank?-----It sounds like you need another rotor.------Sent a couple of these motors to scrap a week ago.
Not so sad boater
Yes I made sure it was lined up when I reassembled it. I was thinking the same thing but I'll find out in a little while when I pull it apart again. That's a shame but I can understand why lol. It fired right up after the amplifier was installed, do you think that being an aged part it could have spun off the notch? Not sure if it's original or not. It looked good so I reused it. It and the points are all that I didn't replace. Everything from the battery to the plugs.
fwiw from an intelligent source... things to reverify ....
If it fired briefly right after the new amplifier was installed, then died and now won’t restart, the most likely causes are:
Most likely causes​
1. Loose / bad electrical connection (very common)​
After changing the amplifier:
  • a wire may be loose
  • bad ground
  • corroded connector disturbed
Check:
  • battery terminals (clean/tight)
  • engine ground strap
  • amplifier mounting screws / ground
  • coil wires
  • kill switch wire
A weak battery or poor cable can let it cough once, then fail because ignition needs adequate cranking voltage / speed.
2. Kill / stop circuit grounding ignition​
Sometimes:
  • key switch
  • kill lanyard
  • chafed wire
can short ignition to ground.
Quick test:
  • disconnect the black/yellow stop wire (or kill wire) from the amplifier / ignition module
  • crank again
If spark returns:
  • kill circuit is the problem.
3. No spark at plugs​
Before chasing fuel:
Do a spark test
  • remove both plugs
  • reconnect plug wires
  • ground plug bodies to block
  • crank
Look for:
  • strong blue snap
Weak / none:
  • amplifier wiring
  • bad coil
  • rotor / cap issue
  • points / trigger problem
These systems need decent cranking speed to produce spark. Remove plugs during testing so the starter spins faster.
4. Rotor not seated / cap issue​
Since you were in ignition:
  • rotor may not be fully pushed on
  • cap may be cracked / damp / carbon tracked
  • center carbon button missing
Engine can fire once, then stop if spark leaks.
5. Fuel issue (less likely if it fired right after repair)​
Check:
  • primer bulb firm?
  • fuel reaching carb?
  • choke working?
If it fires on a tiny shot of premix into carb throat:
  • fuel delivery problem.
Best next step (in order)​
  1. Charge battery fully
  2. Check all grounds and amplifier connections
  3. Test spark on both cylinders
  4. Temporarily isolate kill wire
  5. Inspect cap / rotor again
Not so sad boater
Most likely causes​
  • bad ground
Check:
  • coil wires
  • kill switch wire
Sometimes:
  • key switch
  • kill lanyard
  • chafed wire
Quick test:
  • crank again
If spark returns:
Do a spark test
  • remove both plugs
  • crank
Look for:
  • strong blue snap
Weak / none:
  • amplifier wiring
  • bad coil
  • rotor / cap issue
Check:
  • primer bulb firm?
  • choke working?
Not so sad boater
I don't have a kill switch by the ignition with the cord The only safety switch kills my start ability not my ignition I have verified all the wires all the connections are tight My grounds are good so half of that information was useless and the other half I insured on installation cuz a bad connection is what caused this whole issue to begin with so I have verified my connections multiple times
Not so sad boater
Most likely causes​
  • bad ground
Check:
  • coil wires
  • kill switch wire
Sometimes:
  • key switch
  • kill lanyard
  • chafed wire
Quick test:
  • crank again
If spark returns:
Do a spark test
  • remove both plugs
  • crank
Look for:
  • strong blue snap
Weak / none:
  • amplifier wiring
  • bad coil
  • rotor / cap issue
Check:
  • primer bulb firm?
  • choke working?
Using a timing light during cranking I only have signal at cylinder 1
68glasspar
After dark have someone crank the engine over while you look under the flywheel and see if the spark is shorting thru the plug wire boots.
Not so sad boater
I did that last night I did not see spark escaping from anywhere. What I have found is a slight wiggle on my rotor when fully seated, this can throw off the ignition timing, when I inspected the copper ring in the distributor I have noticed arc marks prior to the brass area that it should be hitting. This tell me it is not firing the spark at the right time. The #1 had spark but it is much weaker than the spark from the coil wire to the distributor. I am currently debating on replacing the distributor, rotor and wave spring to insure all parts are new. That only leaves the key switch itself or the harness but I have verified all needed signals to produce spark
68glasspar
You really need to find out if your spark is strong enough to start with! purchase an adjustable gap spark tester and set it to 3/8in. then check spark at the coil wire. If spark wont jump 3/8 at the coil, diagnose that first! If it does jump 3/8 at coil wire, then proceed to check at each spark plug terminal. If you have spark to weak to jump 3/8in at the spark plug wires, then MAYBE you have problem with cap and rotor.
68glasspar
You stated you had a slight wiggle on the rotor! Does the crankshaft have side play? If you have side play(excess play)that will affect the point gap!
Wave washer secures the rotor !----Rotor does not control timing.----Opening of breaker points controls timing
Not so sad boater
Spark from coil wire jumps 1/2 nice blue spark. Extremely weak spark at plug #1 had to 1/8 from ground to get a spark. I have nothing at #2 or #3 signal tested with timing light. I'm leaning towards cap and rotor it's all it can be. I'll have to wait to buy the part they are another $400 for the cap and rotor.
Not so sad boater
No play in crank the wiggle is at the notched area it can turn side to side in the notch it sits in, my understanding is that it has zero play tolerance. Despite play from side to side can cause it to throw the spark at the incorrect time causing the plug not to fire correctly or not at all according to what I understand.
Not so sad boater
I verified the gap on my points on all lobes twice just to be sure that nothing exceeded the recommended adjustment. I'm thinking I got a bad distributor because it doesn't seem to be taking the spark and putting it where it was supposed to be so I'm going to wait and save my money and order a new cap and rotor
