- Joined
- Jul 23, 2011
- Messages
- 52,521
8000hp motors are acceptableInsurance companies accept 800 hp crate engines ?
It has to do with the load path. An I/O or IB is pushing the boat from low on the transom. Basically you cant put enough power to tear the transom off with an I/O or IB unless the transom is rotten
An outboard is trying to pry the transom off the boat, and will even with a good transom. The longer the leg, the more transom ripping torque applied
