projects other than boats
flashback
The last v8 I was into was a 10 year old 57 Chevy. Back then we would put solid lifters and a 3/4 race cam. After going through your links I see that cams are much different than then. Don't know if solid lifters are even used anymore let alone two 4 barrel carbs, witch was a good time in those days.
for the 5.3, I am going total luddite build on this one. basically 100+ year old technology that is still with us today vs the electronic-du-jour that will not be around next year. controlling the suck-squish-bang-blow in a manor that will remain relevant next year as well as 2050
Induction will be a Victor Jr clone intake and a holley HP830 carb. simply because bernoulli's principle still applies and I can get parts for a 40 year old carb where I can not get parts for a 40 year old EFI setup
the coils and their placement have already been determined and they will go in the cowl to hide them. they will not be sitting on the engine as that just looks wrong
that leaves spark management. going down a rabbit hole of thoughts and parts research for the Fiat build
on one hand, the MSD 60143 ignition controller.
https://images.holley.com/583x/60143_05.jpg
this is designed for the LS, it requires both the cam sensor and crank sensor (both which often fail) to deliver a spark. I can customize the maps, and there is a 2-bar MAP sensor should I need one. while the 6014 is a giant leap beyond the 6010 or 6012....... they still have about a 3% failure rate
or I can go billet flathead V8 mechanical advance dizzy and simply modify the timing cover and make a cam drive for the dizzy tang
https://www.speedwaymotors.com/_next/image?url=https%3A%2F%2Fcontent.speedwaymotors.com%2FProductImages%2F9108352_L1600_d52fe917-8d6e-4b1f-a771-d360ed8ce03d.jpg&w=750&q=75
Its billet, based on a simple magnetic pickup and has mechanical advance. it has two components that potentially can fail, the pickup and the cap
the cool factor would be the dizzy if I have room. however that remains to be seen as the radiator is only a few inches forward of the block
the easy factor would be the FUGLY MSD box.
the low cost factor is the dizzy
the expensive option is the MSD
the only thing holding me back on the dizzy is space and the fact that the dizzy uses a crab cap...... those that know the internal design flaw of these cross-talking beauties
Well........ I answered my own question. driving off the cam wont fit with a crab cap. wonder if I can modify the Voyager EST box and cut-down a billet dizzy body.
and yes, while there are front dizzy mounts from weneger for the racing an now street rod market https://www.wegnerautomotive.com/drive-kits/lsx-drive-kits/distributor-ignition/wak011/
it wont fit with the damper I need......
so looks like I am stuck with the MSD60143
Next to look into the starter mount. most likely have to follow this path.
looked into buying one. no longer available. the guy that runs ls4king had an accident. they now have stainless versions.
going to either modify the stock pan or make my own.
Progress on the closet shelves..... waiting glue to dry to move clamps
Sorta boat related. Hydraulic folding bulwark beaches going together
Yellow tape for work instructions to tell the crew where the zip ties go
Saw this on facetube......
I would so drive it.
Well....... The block is non-useable for anything but fitment.
The pan is mostly intact and can be modded as a starter mount
The crank has heavy scars
There are at least 3 wrist pin snap rings amongst the bits
The crack on the outside AC compressor boss stems from the hole on the inside
Can not get an advance curve on the SCE flathead dizzy from either Speedmaster, Procomp (same company), or speedway motors. I may end up buying one just to look at the advance mechanism to determine if its feasible. If it matches the stock flatty curve of 22 degrees, all in by 2000, then its feasible. however the dizzy doesnt have a vac advance. so part throttle cruise will not be as efficient. plus, besides my rough estimate in CAD, this pic shows it wont fit cam driven.
Motor vehicle Automotive tire Light Automotive design Rim
however could work belt driven, just sitting higher on the block
So, while spelunking on the inteweb in one of the 36 browser windows open.......
I noticed that MSD dropped their prices by over 10% from $523 down to $470 (they recently raised them 50% from $384 to $523)
the Daytona Sensors route by the time the MAP sensor is added, its higher. Base of $462 plus $70 for the MAP
the Microsquirt rabbit hole, $360 for the MS V3, $30 for a MAP, make a harness....... I am into it for the same price.
Today's fitting the hickory jigsaw puzzle...... And the admiral has a few changes
Everything is tight. Sanding the joints to account for the finish
I'm glad my house is too small for a fancy walk in closet
the closet is only 92 x 71. so there isnt a lot of room. Tammy has enough stuff in there to fill a 12 x 15 walk in closet.
